Default Value for a Slicer
My visual returns the correct values when a slicer selection is made. However, the visual errors out when no selection is made.
What can I do to have a default value selected if the slicer is cleared? Thanks for your help.
Regards,
Rupert
@Robert,
Check out the video below, which walks through this issue in detail:
Yes, see here as well
But you can also use SELECTEDVALUE function, which is probably the best option actually these days.
Thank you for your quick response. This solution works and I truly appreciate your help.
Thanks, Sam. I tried your solution and it works for me also. I now have two solutions to my problem. have a great day.
