We have a daily revenue dashboard which allows the user to compare the daily revenue to a budget allocated by days in the month and the two year historical work day average.
Rarely, some charges will be entered incorrectly, generating an enormous revenue amount, say, 10 million. The following day, someone catches the error and will then create a reversing entry of -10 million. These entries create very large swings in the historical work day average.
The data entry issue is always going to be there. How can I mitigate these swings? What would be the best way to exclude outliers?
That issue bring back memores for me!!! We had a 10 m error when I was doing reporting on weekly basis. We made a correcting general Ledger entry for the day it happen. For example if the error happen on Monday May 8 but it wasn’t discovered until Monday May 15. We made the general ledger correcting error entry for May 8 not May 15. The net affect would be zero for that day.
If the error happen within a system generate then go back to the source and correct it there for the same date as the error happen. If the error couldn’t be corrected until the next month then make a entry for when the entry happen in May and reverse it out when the system is corrected in June.
If you know exactly what day it happen on then just disregard the 10 m and do the difference of it for budgeting purpose.
EDIT…it looks like I didn’t hit the Reply button .
Hi Keith, thanks for the reply.
This is historical data from a patient billing system. The information has already been corrected. Using your example, the business office entered a charge for $10m on May 8th and discovered the error on May 15th and created a reversal for ($10m).
I’m wondering if determining a Z score for the workday would be a solution?
I think i would just make a comment area that states the error information. (just abnormal activity)
If it happens again, I would make sure a general ledger entry is made for that day that it error happen. When the system gets corrected then reverse that entry on the day its corrected.
Since the errors are usually caught within a day or two of the error, the reversals are loaded to the GL at the same time with EOM as the date. It’s in the daily reporting from the billing system that I’m trying to address.
All I did in that case, I made a note comment on the report that it was being investigated. Personally, i wouldn’t do an EOM entry, I always did an entry on the day of the entry the error occured.
