DAX Workout 020 - Dynamic Titles and Subtitles
Challenge:
In this workout, you will create a dynamic title and subtitle for total sales with forecasting variance, including green and red arrows or icons to indicate positive and negative values along with the percentage in the subtitle.
The trick here lies in how you format the subtitle and the main title. It’s all in the padding and conditional formatting to get the different font sizes and colors.
Even though the Sales amount and the percentage value are on the same line, they are independent.
Also, in this dataset, I have included forecasting values for you using RAND(). A column called ForeCastingRand has been added to the Sales Table.
Feel free to bring in your own generic forecasting numbers to use. You will need Forecast Difference and Forecast Percent Difference.
Best of luck to you!
DAX _20 - Dynamic Title 05252023.pbix (667.6 KB)
Submission
Load the supplied data file into a new Power BI file, create your solution, and reply to this post. Upload a screenshot of your solution along with the DAX measure. Please format your DAX code and blur it or place it in a hidden section.
Period
This workout will be released on Thursday, May 25, 2023, and will end on Sunday, May 28, 2023. But you can always come back to any of the workouts and solve them.
@Paul.Gerber just for clarification, is this highlighted number supposed to be the percentage difference between total sales and total Sales[ForeCastingRand]?
Yes you are correct
Good question. The FC is the forecast
ok. if that value is correctly calculated on your side then i must be misunderstanding something :laughing:
Give me a minute and I’ll double check
@HufferD it should be -20.9%
that’s what I thought. lol thanks for clarifying :sweat_smile:
@HufferD I know you are on the right track. I don’t why that value was there. But I checked my solution.
-20.9%
Thanks, David
It happens. thanks for clarifying. I see it’s fixed at the top, too. I was thinking maybe you had an unexposed filter on the original or something. I didn’t pull my hair out or anything.
Thanks for asking
@Paul.Gerber
My submission:
submission
Thank you for planning this exercise.
This looks great! I like how you have a slicer to change the icons
Hey All,
Here is my Submission
Dax Measures :
ForecastDifference AsTExt = “Total Sales”& REPT(UNICHAR(10),2) & Rept(" “,30) & FORMAT([ForecastDifference%], “+0.0%; -0.0%”) & " △ FC " & If([Total Sales] > 0 ,” :green_circle:"," :red_circle:")
Total Sales as Text = FORMAT([Total Sales], “#,##0,.00M”)
Thanks for the workout, here is my submission
DAX Measure
This text will be hidden
Total Sales text =
"Total Sales" & UNICHAR ( 10 )
    & REPT ( " ", 28 )
    & FORMAT ( [Forecast Difference %], "0.0%" )
    & REPT ( " ", 5 ) & "△  FC"
    & IF (
        [Forecast Difference %] < 0,
        " " & UNICHAR ( 11167 ),
        " " & UNICHAR ( 11165 )
Maybe Its a case of the Memorial Day Weekend Hangover (even though I don’t drink). My percentages are way different…
Total Sales = SUM( Sales [Line Total])
Total Forecasted Sales = SUM(Sales[ForeCastingRand])
Forecasted Difference = [Total Forecasted Sales] - [Total Sales]
& Difference = ???
For Example: Using the numbers from Above (Greece / Latvia) in 2021
Sales: 2,968,274
Forecasted: 2,076,897
Difference: (891,377)
Difference % ?
Thanks in advance. Maybe I’m reading the instructions wrong.
more likely is that your numbers are off because of the random number. if it isn’t a set seed, the values will be different on every refresh.
