Is it possible to create a virtual table which returns a different measure for each row based on some logic……….and then expect SUMX to produced the desired result in the total row?
Attached is a dummy .pbix of the scenario required in full (mimicking coding and source systems from real data). Presenting it as a DAX problem, but could well be a data modelling answer!
Summary:
Require a solution to view Income in the view of a Corporate partner to a Charity, where applicable, if not just view it as an individual supporter. Scenario is that Microsoft could give a donation from Head Office, their UK office or an employee could run a race for them. So the standard view would be income per those three Supporter records. However also want to see the view of Microsoft as a whole entity. This seems to be OK, but then add another individual who is not coded to raised for Microsoft and the current measure doesn’t evaluate correctly.
Corporate Dummy Data.pbix (31.0 KB)
Hi @pmcmonag
Yes possible. Try this
I hope that you are having a great experience using the Support Forum so far @pmcmonag.
Kindly take time to answer the Enterprise DNA Forum User Experience Survey, we hope you’ll give your insights on how we can further improve the Support forum. Thanks! Thanks!
Hi @pmcmonag, did the response provided by @Rajesh help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @pmcmonag, we’ve noticed that no response has been received from you since the 25th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @pmcmonag, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks.
