Hello EDNA - some GURU help would be apperciated. looking to convert a working DAX calculated column to Power Query. looks like I need this before an append query.
here’s the WORKING Dax Code:
Rate2 =
MAXX (
FILTER (
EquipRates,
EquipRates[EquipType] = Data[Name / EquipType]
&& Data[Tdate] >= EquipRates[DateStart]
&& Data[Tdate] <= EquipRates[DateEnd]
EquipRates[Rate]
Thank you in advance,
Frankee
Hi @Frankee,
Don’t think that will be a problem.But you know the drill.
Share a PBIX with dummy data as well as an XLSX. Dont forget to include the expected outcome.
Cheers!
Hello @Melissa - thanks for the reply …I got you.
here are the files. the desired result is in the PBI file…DATA table. Rate2 column, see pic
Resolved with these two posts:
https://techcommunity.microsoft.com/t5/excel/power-query-lookup-value-between-dates-in-a-separate-table/m-p/3660435?attachment-id=56291
and
nested if
Thanks Again,
Frankee
