I’m trying to create a DAX measure that excludes positive values from an existing measure named “Write Off”. This measure calculates the difference between invoiced amount and invoiced amount billable. Thanks in advance. Here’s the existing measure definition:
Write Off = Invoiced Amount Time - Invoiced Amount Billable
Note that these table are already the results from the measure and I wanted to exclude the positive values and retain the negative values.
Hi @mspanic, thanks for your help! I understand your approach, but what if the “write off” already exists as a measure instead of a column? How would I modify the code to accommodate this change? I tried the below but obviously, there will be an error. Thanks so much!
