DAX help required
Hello Team,
Am looking for 2nd level drill down value to be calculated to 100 percent, as you can see the below sample screenshot the split of 89 has to come to 100% percent but its coming to 08 (89%) (6 (67%)+1 (11%) +1 (11%)) can we get the split like 08 (89%) and below
(6 (75%) +1 (12.5%)+1 (12.5%).
I have attached PBIX file for your reference.
Percent_Sample_file.pbix (151.4 KB)
Hello @Dharma,
To achieve the results based on the condition that you’ve specified. Below is the measure alongwith the screenshot of the final results provided for the reference -
Percent Of Total - Harsh =
VAR _Total_Empls =
COUNTROWS( 'Data Table' )
VAR _Total_Empls_Each_Country =
CALCULATE( COUNTROWS( 'Data Table' ) ,
    ALLSELECTED( 'Data Table'[Country] ) )
VAR _Total_Empls_Each_Type =
    ALLSELECTED( 'Data Table'[Country] ,
        'Data Table'[Order] ,
        'Data Table'[Type] ) )
VAR _Percent_of_Total_Empls_Type_Level =
DIVIDE( _Total_Empls , _Total_Empls_Each_Type , 0 )
VAR _Percent_of_Total_Empls_Country_Level =
DIVIDE( _Total_Empls , _Total_Empls_Each_Country , 0 )
VAR _Results_For_Type_Level =
FORMAT( _Total_Empls , "0,0" ) &" ("& FORMAT( _Percent_of_Total_Empls_Type_Level , "0.00%" ) & ")"
VAR _Results_For_Country_Level =
FORMAT( _Total_Empls , "0,0" ) &" ("& FORMAT( _Percent_of_Total_Empls_Country_Level , "0.00%" ) & ")"
VAR _Results =
SWITCH( TRUE() ,
    ISINSCOPE( 'Data Table'[Country] ) , _Results_For_Country_Level ,
    ISINSCOPE( 'Data Table'[Type] ) , _Results_For_Type_Level ,
_Results_For_Type_Level )
_Results
Thanks and Warm Regards,
Harsh
Percent_Sample_file - Harsh.pbix (150.7 KB)
Thank you @Harsh as always very precise solution… :grinning:
Hello @Dharma,
You’re Welcome!! :slightly_smiling_face:
Harsh
