Hi All,
I need help in writing a DAXTesting for CPL.xlsx (17.6 KB) measure to find out the values highlighted in yellow as per the attached sheet
Regards
Kran
Hi All,
Regards
Kran
Hello @Nagi_k,
For the first formula
% Calcul =
VAR _TotalCTL = CALCULATE([Total CTL], ALL(Sheet1[Row Labels]))
DIVIDE([Total CTL],_TotalCTL,0)
For the second DAX formula I do not understand exactly what you want to compute. % over Sum CTL generic?
Calcul =
VAR _Generic = CALCULATE([Total CTL], Sheet1[Row Labels]="Generic")
VAR _Result =[%]*_Generic
RETURN _Result
Hope it helps,
Best regards
Thank you Alex
