I there way by using Dax formula to make the value bold and underlined ( as colour in conditional formating. ( Iam using the financial template within the matrix.
Hi @WimH
As far as I know, it is not supported but you can vote for this idea at:
https://ideas.powerbi.com/forums/265200-power-bi-ideas/suggestions/11602134-additional-font-formatting-bold-italic-underlin
Hi @WimH , we’ve noticed that no response has been received from you since the 27th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
