DAX Formula Filters
Hi guys,
In 1 column I have a number of regions ( 1 to 4) and in another column I have incident class ( 1,2,3,4,5)
I am trying to create a card with the total number of Region 1 and incident class 1 (for example). See below columns. Basically how many (count)incident class = 1 has region 1.
I am having mental DAX block today and can’t get it right.
I hope I am making sense, first question in the forum - hope is Ok.
Federico
@FPastor,
Welcome to the forum - great to have you here!
In general, you will get the best response if you post a copy of your PBIX file and a mockup of the result you want to see. For your measure, try this:
Measure =
CALCULATE (
    COUNTROWS ( Table ),
    FILTER ( Table, Table[Incident Class] = 1 && Table[Ops Region] = "Reg 1" )
I hope this is helpful.
Thanks for posting your question @FPastor. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Thank you Brian,
It works to perfection.
Regards,
Federico
@FPastor,
My pleasure - glad to hear that worked well for you.
