Dax Formula Combination
Hi Everyone and Sam,
I am trying to create two dax formulas then try and combine the results.
Formula 1 is as follows:
This is a simple formula that just provides me with average sales of each month across each year and works as desired.
Formula 2: i am having trouble creating this formula - i am trying to calculate my sales experienced this year ONLY. E.G if the year is 2018 i only want sales from january -> now().
I then want to combine these two formulas to create a prediction. If the year is 2018 and the current month is august i want the actual values in formula 2 to be displayed up until august and then the following months have the numbers from formula 1 as a prediction to give me one trend line
any help is appreciated,
cheers
Hi Robert does the detailed here solve this.
A lot depends on the content this calculation is in, and I’m not sure by the post.
Logic like
IF( LASTDATE( Dates column) <= TODAY(), true results, false results )
This usually works.
Another way you can do it is you can have a switch column inside your dates table that just runs simple logic like this.
IF( Dates column <= TODAY(), True, False )
Then you formulas only require a FILTER referencing this particular field.
I think the first one is more likely going to be your best bet I would say.
Check out the video it describes it there.
Here’s another one to review as well.
