Dear all,
Is there a DAX formula for calculating the MODE function?
If no, how can I write a DAX formula for this?
Thanks.
Dear all,
Thanks.
Hi @Khaiboon,
Welcome to the Forum.
Alberto Ferrari and Marco Russo have an article on statistical patterns in DAX which can be found here.
The mode is the value that appears most often in a set of data. This formula ignores blank values, which are not considered part of the population. The result is identical to the MODE and MODE.SNGL functions in Excel.
Mode =
MINX(
TOPN(
1,
ADDCOLUMNS(
VALUES( Table[Column] ),
"@Freq", CALCULATE( COUNT( Table[Column] ) )
[@Freq],
0
Table[Column]
I hope this is helpful
Hi Melissa,
Thanks so much for your reply.
I will check out the link and also try out the DAX you provided.
Cheers!
Hello @Khaiboon
Thank you
Yes, it works! Thanks !
