DAX for calculating a filtered value per month
I feel really stupid for asking this question.
However, can anybody help me with the DAX for calculating the number of ‘accepted’ and ‘rejected’ incidents per month? I want to be able to create a gauge with a target value etc.
I have attached a screenshot of my table.
imageDAX.docx (194.8 KB)
@chrisgreenslade No question is ever silly if you learn something from it. Having said that, you can try something like this:
    Accepted =
    CALCULATE (
    COUNT([The Column with Accepted/Rejected]),
    [The Column with Accepted/Rejected] = "Accepted")
  Rejected =
        CALCULATE (
        [The Column with Accepted/Rejected] = "Rejected")
When you bring these measures in a visual with Month, you will get the Accepted/Rejected incidents per month automatically if the Incident Type table has a relationship with the Date Table.
I hope it helps.
Thanks.
Mudassir
Thank you so much!
Thanks :grinning:
