DAX Feedback Request
Hi everyone, I would like to share this comparison for feedback from the forum. Both formulas iterate the average time in status of total loans for each underwriter ( row ). It takes into account zero values as well as the total average ( total row ). Both have the same results on the matrix.
VERSION 1
VAR _oneValue = HASONEVALUE ( UWtracker[AssignedUW] )
VAR _avgx =
AVERAGEX (
    ADDCOLUMNS (
        SUMMARIZE ( UWtracker, UWtracker[Loan Number], UWtracker[Days] ),
        "@Days",
            CALCULATE (
                IF (
                    NOT ( ISBLANK ( SELECTEDVALUE ( UWtracker[AssignedUW] ) ) ),
                    VALUES ( UWtracker[Days] )
    [@Days]
VAR _result =
    SWITCH ( TRUE (), _oneValue, _avgx + 0, _avgx )
    _result
VERSION 2
VAR _notBlank =
    NOT ( ISBLANK ( SELECTEDVALUE ( Underwriters[AssignedUW] ) ) )
VAR _avgx =
    AVERAGEX (
        DISTINCT (
            SELECTCOLUMNS (
                UWtracker,
                "@Loan", UWtracker[Loan Number],
                "@Days", UWtracker[Days]
        [@Days]
VAR _result =
    SWITCH ( TRUE (), _notBlank, _avgx + 0, _avgx )
    _result
Version 1 visual rendered slightly faster on the performance analyzer.
Bumping this post for more visibility from our experts and users.
I realized soon after this post that version one did not produce the desired result.
Hi @Schreg,
Based on the latest update you’ve provided, I’d like to check if you still require assistance for this post?
Thank you!
Hi @Schreg
We’ve noticed that no response was received from you on the post above.
Just following up if you still require assistance to solve your inquiry.
not necessary
Hi @Schreg - If no help is needed. Can you mark this as solved and close it.
Thanks,
Ankit J
