DAX Editor Pro Enterprise DNA Addon
Hi All,
I have installed DAX Editor Pro Enterprise DNA Addon, which works great if I create a new PBIX file, however it displays an error in existing files?
" The remote server returned an error : (401) Unauthorised"
Any help I will be grateful
Rich
Hi @rich871071
After you installed the program, did you close power bi then restarted it?
I opened up an existing file that i created and then open up Dax Editor pro and it open fine for me.
No error on my side.
I know sometime if you install a new addon, you have close the program and reopening the program.
Keith
Hi @rich871071, have you tried the suggestion of @Keith? If you have and it solved your issue, kindly close this post by tagging his answer as solution. Thanks!
Hi @rich871071, we just want to check if you still need further help with this post.
Hi @rich871071, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
