Hi - I need help in getting my Date Col and Time Col together into a new DateTime column, I have tried loads of things including
Date Time = CN_FXD_PRICE_CHNG_LOG[CFPL_DATE] & " " & TIME(HOUR(CN_FXD_PRICE_CHNG_LOG[Time]), MINUTE(CN_FXD_PRICE_CHNG_LOG[Time]), SECOND(CN_FXD_PRICE_CHNG_LOG[Time]))
and
Date Time = DATE(YEAR(CN_FXD_PRICE_CHNG_LOG[CFPL_DATE]), MONTH(CN_FXD_PRICE_CHNG_LOG[CFPL_DATE]), DAY(CN_FXD_PRICE_CHNG_LOG[CFPL_DATE])) & TIME(HOUR(CN_FXD_PRICE_CHNG_LOG[Time]), MINUTE(CN_FXD_PRICE_CHNG_LOG[Time]), SECOND(CN_FXD_PRICE_CHNG_LOG[Time]))
but can’t get anything to work, pbix file attached thank you for any pointers you can give. Lizzie
Hi Lizzie,
that PBIX table, where your columns reside are from your Direct Query model so I can’t view them, seeing the data you’re dealing with would help.
Are you able to post a dummy PBIX? One thing I would add, it’s always a good idea to mask data when publishing onto the forum so you don’t publish anything sensitive.
David
Hi @LizzieTompsett,
I create a really simple example with a Date columns and a Time columns.
I use Power Query to concatenate the two columns in the right format using a Custom function.
You can see my example below.
Book1.xlsx (10.8 KB)
Untitled.pbix (55.8 KB)
I hope it will help you.
Best regards,
Joaly
Hi Joaly
Thanks for your post, I created a dummy pbix file too and the DAX measures all worked so it must be something to do with the date field coming from the ERP system. As it is a direct query I can’t use the concatenate in Power Query. I spoke to the IT company and they said the field has a DateTime data type and cannot be changed.
What seems to be happening is that for e.g. 31/07/2021 is actually 31/07/2021 00:00:00 and then won’t properly join with another time field.
I am trying to find a way in Power BI to get rid of the 00:00:00…
Thanks Lizzie
Your problem is clearer now.
I’ll come back to you if I find a solution
Is a formula like this one works in your model ?
Using a “+” instead of a “&”.
Oh my goodness Joaly - you are a genius!!!
The + instead of the & worked, thank you so much for your help, I have spent days trying different things!!!
Best regards Lizzie
Your welcome @LizzieTompsett
It’s a pleasure
Have a nice day,
Joaly
