Hi Brian,
I will do so, the data I link to is from our data warehouse, will need to try and mask the data etc.
Will check out the masking data steps you’ve posted.
Hi Brian,
@DavieJoe that’s the only thing i could think of
Very much appreciate your efforts to help @Keith
Hi @DavieJoe did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
I’ll hopefully be able to post my PBIX tomorrow, I’ve been away on a short break.
Hi @DavieJoe, we’ve noticed that no response has been received from you since the 14th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @DavieJoe, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
