There are existing questions about the date format of the slicer but it seems to involve changing the regional settings in the browser which affects the PBI service?
I am only using the PBI desktop and I can confirm the date (on the bottom right of the Windows taskbar) is showing as dd/mm/yyyy which is the UK format but my PBI file still shows the US format when displaying in the slicer.
Thank You for posting your query onto the Forum and for providing the PBIX file.
Well, this is quite an unusual nature because when I imported or downloaded and opened up the file in my machine it works fine i.e. it shows the date format as “DD/MM/YYYY”. Below is the screenshot provided for the reference -
As you suggested that you can see the format correctly - “on the bottom right of the Windows taskbar” but not in the Power BI. So atleast you can try and set the “Regional Settings” under the “Current File” menu to “English (United Kingdom)” and then restart the Power BI Desktop, if required. Below is the screenshot provided for the reference -
The only way I know to change the date format in the slicer is to change the Regional settings in the “Windows Control Panel”.
I’m using Windows 10 and my default regional setting is set to French (FR) there for the date format in the slicers are always in dd/mm/yyyy format even if I choose another (or set a custom) format for the dates fields.
I have solved the issue by changing the regional settings in Control Panel. However, this is strange behaviour from Microsoft as my previous settings were English (HK SAR) and we use the dd/mm/yy format. I had to change it to English (UK) and the slicers worked.
