*** READ FIRST ***
Hi all,
In my date slicer, there is a blank value selection. But when I click on the blank value selection, there are no blank data. How can I remove the blank value from my date filter?
Thank you.
*** READ FIRST ***
Hi all,
Thank you.
Hello @ysherriff,
Patrick from Guy In A Cube had created a video on pertaining to the topic. Below is the link of that video provided which you can check it out.
Hoping you find this useful and solves your query.
Thanks and Warm Regards,
Harsh
Hi @ysherriff
You can try this out. Drag your field onto the canvas and Select the Visual in which you can filter the blank value using page level filters and then change that visual to the slicer.
You can also try out the video posted by @Harsh as Patrick from Guy In A cube explanations are so cool to understand.
Regards
Thank you. Both suggestions work.
Good to hear that @ysherriff
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
Thank you for the feedback.
