Dear eDNA forum,
I would like your help to solve the following task:
- I have a report which I weekly update with some new data and am struggling to find a logic to combine old and new information and keep or replace some of them based on the value of some fields
On the left (green) the combined report and on the right (blue) is what I would like to achieve:
Basically:
- For Deals which were already in the previous report and repeat in the second one, I would like to keep the Type = /PAST/ but get the new Revenue value (first 2 rows of Blue table), while the others I would just carry the values they have as they do not repeat
The working file is called EDNA_FORUM_COMPARE, please populate the parameter FOLDER_PATH with the ‘DATA’ folder path in your computer to have the file working
WK12.xlsx (20.1 KB)
WK11.xlsx (20.0 KB)
EDNA_FORUM_COMPARE.xlsx (21.5 KB)
Attached the working file
Thanks a lot for any suggestion
Ciao Antonio,
-build a custom column with if [Type] = "\Past" then null else "\Past"
-merge the table with itself, Type & ID with Custom & ID
-expand and you will only have two matches
-replace Total Rev with Custom if Custom is not null
-remove duplicates on Deal ID
=> Done!
Regards,
Matthias
Hello @Anferrig
Thank you
Hi @Anferrig
Due to inactivity, a response on this post has been tagged as “Solution”.
Ciao @Matthias,
thanks a lot for your reply
the notification ended up in spam so am seeing it only now
I will try the solution and let you know how it goes
Very sorry for the delay
Wish you a nice day
Antonio
