I am having real problems with a dataflow that i have which is pulling the General Ledger Entry Table from Dynamics 365 Business Central, the dataflow keeps falling over giving the following error:
OData: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host
The dataflow falls over about 50% of the time every day which is starting to affect my reports as they are obviously not as up to date as they should be. The dataflow output is less than 50k rows and i’m only doing 1 calculated column which is just adding the company name so when i append the queries i know what lines relate to what company.
I have tried splitting out the dataflow into smaller chunks of data based on the posting date but still no joy.
I have spoken to my small IT team who are not really interested in helping they have said this is a Power BI issue but i get the feeling they said this to get me to go away!
Dataflow info:
Odata v4 connection with filters to select only certain columns
4 seperate queries, 1 for each company in BC
The queries are not loaded, I have appended the queries and this is the data that is loaded.
Pro licence / workspace
I tried putting a timeout at the end of my api connection link but this doesn’t help: Timeout=#duration(0, 0, 30, 0)])
I have also tried putting a posting date filter ($filter=) to scale down the amount of rows but still doesn’t work.
I tried using a Web Api / Json connection which works much faster than the Odata conenction but only returns 20k rows so not a solution.
Any info / help would be appreciated.
