My name’s Frederick aka Eric. I’m quite new to our site. My question is very simple:
I noticed that some lectures automatically go into discussing the topics without stating where the specific data sets/ workbooks could be found. An example would be the ‘DAX Formula Deep Dives’ mini series. I’ve tried searching for any link nor lecture that points to the actual work books/ downloads and I can’t seem to find it.
I’m back again because I saw the 16 min video on how to use the platform. But still, there are several videos wherein the lecture starts right away and I can’t find any sign of the workbook/ data sets to be used. Here are links to some of these courses:
My issue here is that the actual data set used by Melissa looks different with the one she supplied. Also, upon using the actual PBI file she used, there is an error within the source file.
*** There may still be other lectures that I may notice in the future, but so far these are the ones that stood out.
I found the source file that @Melissa is using in the Power Query - language. I found the excel that she is using the zip file in the What is power Query and how to Master M Course.
I hope this helps.
Note. there are zip files within each video course
Keith
Hi @Fred_Z, did the response provided by @Keith and @Melissa help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Fred_Z, we’ve noticed that no response has been received from you since August 5.
Hi @Fred_Z, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
