Hi every one ,
could you please help me with the problem related to data model . i have table promotion to be related to tab facture( invoice) but we have d
uplicates so i am strugle with M:M relation ship.
202309_Test.pbix (31.5 MB)
Hi @ayari
I taken a look at your data model. Its really confusing what are fact tables and what are dimension tables.
could the two tables be combine instead of two separate tables?
Did you take any of the courses within EDNA learning portal?
Data Transformations And Modeling
thanks
Keith
Hi @ayari ,
It seems like you need to consider what is the granularity for this process
to solve Promotion N :N Facture relationship
For example:
- is it product on facture that can be on 1 promotion ?
- if not - what else need to be unique - facture order line ?
- etc.
Good luck
Hi @Keith
thanks for your reply.
i tried to combine the two tables , but i coudn’t.
For the courses , no i did not take . if you could recommend to me .
thanks
Hi @mspanic ,
thanks for your reply .
in my case the product can be in multiple promotion ( differrent date of promotion). i am working to find a unique key , but with no result.
Merci encore une fois
Hi @ayari ,
Je vous en prie,
maybe following questions can help:
From your last post I didn’t figure out - on the same time (on one Date for example today) - product can be in one 1 or more promotion ?
How the promotion is physically presented on the bill / facture ?
Bonne chance
I put the information in my message Data Transformations And Modeling. I would suggest that you view the courses to see
The problem was solved by combining the two tables.
I will have check the course.
Thank you .
have a nice day
