Good day
need some guidance on data modelling, i have 6 fact tables from different sources and i would like 1 lookup table with 2 values:
- Region
- Country
all fact tables have Region and Country present, i have managed to make 1 relationship between region but make the country relationship
getting the below error, any advice on how to get around this?
Hi @neilonbooysen,
I see a couple of challenges here in the screenshots.
- you should have a single key column in a dimension/lookup table
- you have nulls in your dimension/lookup table
- you have bi directional relationships between your fact- and dimension/lookup tables
The solution is to generate a unique key for each Region/Country combination in the Dimension table maybe by concatenating those values in a new column.
Next make sure your Key column doesn’t include nulls and has a value for each possible combination present in your fact tables.
Combine all Region/Country fields in your fact tables as well, to generate the same Key and link the tables on this column in a one-to-many, single direction relationship from Dimension to Fact.
I hope this is helpful
thanks Melissa for the insights, this definitely guided me
