I am unable to change the colors of my data labels for a donut chart. I saw an older issue from 2022 but it said it was resolved. I updated to the newest February 2023 update and that is when this issue came up.
Is this a problem for anyone else?
Scenario Analysis.pbix (408.0 KB)
This is a lesson from EDNA and I have the same issue with these as with my own data. I thought this might be easier than anonymizing my data real quick.
Assuming that you are looking for an option to apply conditional formatting, from my perspective, what you need is to use one category/column for “legend” field. It allows you to conditionally format the font color basing i.e. on selectedvalue function.
If your intention is to apply standard font colors (w/o fx options), feedback provided by @Greg should solve the problem.
Scenario Analysis.pbix (412.2 KB)
Hi @michael.gyure. Try the Detail labels\Color section of the Format pane.
Wow I can’t believe I didn’t catch this. Thank you for the help and you were absolutely correct I had my value in the details pane. Thank you for helping me with this. ![]()
Hello @michael.gyure
Thank you
Due to inactivity, a response on this post has been tagged as “Solution”.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,.
We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
