I have a very simple question but I am unable to find answer. I am creating a data flow which is bringing Millions of records. It times out after 20 minutes. Is there a way to check timeout setting and change those settings?
I am using Power BI pro account but unable to find these settings.
Thank you so much @Heather. I believe it will solve my problem. The issue did not appear again in my dataflow, but if it appears again, I will try to put timeout manually using the advanced editor. Hopefully, that will be the solution.
Thanks again for putting me in the right direction.
