I have a connection to a database which stores utilisation for users, due to the volume of Data and the method of connection our IT team says that we must query this data month at a time which is not ideal. Normally i would just query all the current live data and bring into PBI but now i will have to extract and store the data by month and then import into PBI.
I am therefore trying to figure out the best way to do this so the end result my data can be imported into my Power BI report.
Current solutions going through my mind are:
Create a flow to extract the data and convert to CSV and store in a SharePoint folder
Create a flow to extract the data and store in a SharePoint list
Create a flow to extract the data and store in Dataverse
Problems to consider:
User needs to specify the month the data relates to
Process needs to work out whether the data covers a duplicate period and if so overwrite but if not add as new
If i opt for database to CSV should i create a CSV file for each month or 1 file and get the flow to add the lines to the bottom of the existing sheet.
I have not done a flow this complex before so any thoughts guidance would be appreciated before i go down a rabbit hole! I’m also open to any other solutions that does not involve Power Automate.
Wow, it’s been a year since this thread started! I hope you’ve made some progress with your data extraction and storage challenges. I think creating a flow to extract the data and convert to CSV and store in a SharePoint folder is a good idea. It’s always good to have a backup of your data, especially if you’re dealing with a large volume. As for the problems you mentioned, have you thought about creating a dropdown menu where the user can select the month the data relates to? Also, I think you might really like Nannostomus. It’s a great service that can definitely make data extraction easy and accessible for every customer. It might be something you need.
Hi there,
It’s been two years since this question was posted, so I hope you’ve made significant progress by now! Still, I wanted to share some thoughts that might help refine or scale your process:
1. **Centralized Storage**: Instead of managing CSVs or SharePoint lists, consider centralizing your data in a database or a cloud data warehouse. This simplifies data management and ensures scalability.
2. **Automate Workflows**: Platforms like [TROCCO](https://global.trocco.io/) can help automate data extraction and transformations, ensuring duplicate checks and appending new records without manual effort.
3. **Direct Power BI Integration**: With several tools, you can seamlessly connect your centralized data source to Power BI, automating refreshes and avoiding repetitive tasks.
Even if you’ve already implemented a solution, adopting a scalable and automated workflow could save time and make your setup more robust.
Happy to discuss this further if you have any updates to share!
It is discourage to post to already solved postings. You can still reference the posting but it is recommended that you start a new posting if you want to see any new solutions.
Centralized Storage: Instead of managing CSVs or SharePoint lists, consider centralizing your data in a database or a cloud data warehouse. This simplifies data management and ensures scalability.
Automate Workflows: Platforms like TROCCO can help automate data extraction and transformations, ensuring duplicate checks and appending new records without manual effort.
Direct Power BI Integration: With several tools, you can seamlessly connect your centralized data source to Power BI, automating refreshes and avoiding repetitive tasks.
Happy to discuss this further if you have any updates to share!Preformatted text
