Dear fellas, the first case scenario in this module, Consumer Goods Sales, has its resources (zip material) a little bit different from the videos. The resources (data tables) are focused mainly on the budget, while the videos and the resource development doesn’t cover it or has it. My question is if the resources are right and we have to figure the transformations out or if is there another resource?
Hi there, sorry for the delay. I’ve just checked the data and it’s correct.
I would update the data source here when you download it to your computer.
Once you see bring in the data into the query editor you’ll see that the model is created a little different than when you just have all the data already available.
You can see this easily by working through the applied steps for each table and query
Hi @benignamlima, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
