Dear eDNA-Community,
I need to export metrics which are a mix of dimensions and theis corresponding measures on a daily basis to offer the ability to show these KPI changes over time.
Output example:
|Dim|Dim|Dim|Measure|Measure|
|Plant|Team|Date|Metric 1|Metric 2|
|1|A|17.01.2024|0,3|233|
|1|B|17.01.2024|0,35|245|
|1|C|17.01.2024|0,33|233|
|1|D|17.01.2024|0,32|222|
|1|E|17.01.2024|0,37|234|
|1|A|18.01.2024|0,5|239|
|1|B|18.01.2024|0,55|251|
|1|C|18.01.2024|0,53|239|
|1|D|18.01.2024|0,52|228|
|1|E|18.01.2024|0,57|240|
Ideally, the Export is appending the new lines to the same Excel on a Onedrive.
Alternatively always create a new file into a onedrive folder
This data shall then be reimported into power bi and show the Measure value history by thos basic dimensions
I wonder what is the best way to accomplish this 24/7/365 fully autonomously, without any clicking on a PowerAutomate-Button or opening an Excel file manually
My solution so far:
An Excel File with a Macro, which connects to the model and extracts the data automatically. But this file would have to be started manually so. The process just takes 10seconds / day
- Virtual Machine? - a bit over the top for just 10 Seconds per day
- Windows 365 with onedrive
- PowerAutomate/Flow
I am also happy do hear how do you tackle the historization of Power BI reports?
Sorry if this was posted before with other key words somewhere else.
Thanks a lot!
