Hell0,
I want to create a slab wise sales table where the size of the slabs is customizable.
Example –
Suppose I have a data table with InvoiceID, Sales Qty, and Free Qty. I want to create a slab wise sales table where users can change the slab sizes and see the results easily.
Hope I have explained my requirement correctly.
Hi @uperera7
You are looking for slab size which user will be updating is in power bi or it will be a separate data source where user will change and update the power bi?
Hello @uperera7,
Well you can do this by creating a secondary/disconnected table in your model. Below are some of the links of the videos provided for the reference.
Hoping you find this useful and helps you. ![]()
Thanks and Warm Regards,
Harsh
Hi @uperera7. You can also check out the dynamic grouping DAX pattern post.
Hi @uperera7 , did the response provided by the Experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
