I’ve come across the same problem, and tried to recreate the Charticulator example from here: tutorial9.html (Bar Chart with Error bars)
but there’s a strange glitch.
I am unable to place any value in the “Mean + SD” field well.
The available field wells are mean, Mean - SD, Mean +SD (along with Primary Key)
At first I thought this was because I was using measures (which calculate weighted means for these values), but I’ve also tried this using columns from the source table, and the same problem exists.
I have tried horizontal as well as vertical bars, and double checked each step from the tutorial, all to no avail.
I’ve attached the .pbviz file: and here’s a screen capture from both the final Charticulator output, and the available field wells:
Bar with Errors 04.pbiviz (247.0 KB)
Any help gratefully accepted,
Rod
