Current Week Calculation
Another Day Another Query,
Sorry for all the Questions but just gone into a new job and using a lot of time intelligence that I haven’t had to use in the past.
I have a Measure Total Quantity and I want to Calculate the Current Week and each of the 5 Previous weeks. What does the Current Week measure look like?
Once I have the Current Week measure do I just have 5 other measures that use the DateAdd Function -1, -2 etc or is there another clever way?
Chris
Hi Chris, check out this forum post from a week back.
This shows you all the custom calendar and weekly work I’ve put out there around time intelligence.
You will just need a small derivative of these. Most like the week on week change I think.
See how you go with these.
If not getting you there post back
Hi Sam,
Thanks for the reply.
How would the calculation look if I was to use the latest date in the fact table rather than a selected value.
Cheers
Chris
So I think your actually look for a rolling total really. Would that be right?
You want to on any day look back over 5 weeks and see how what the total aggregation is?
Something simple like this would do it then I would have thought
Previous 5 Week Sales =
CALCULATE( [Total Sales],
    DATESBETWEEN( Dates[Date], MAX( Dates[Date] ) - 35, MAX( Dates[Date] ) ) )
Can you add some images of what you mean if I’m not understanding this correctly.
I’m having to guess what the context/model is etc. which makes it difficult
Hi Sam
I want a grid with the 5 previous weekly totals backwards from the Current Day. So when I get to next week the first total will be from this week.
Does that make sense?
Chris
Look into think really your best bet is 5 measures to get those results.
Actually you could also have a matrix where the columns will be divided up by 1,2,3,4,5. (You would need to create a need table with those number in it.
Then use SELECTVALUE(WeekColumn) within you measure to dynamically create the results for the right week.
This make sense?
Can be done, now that I know what you need
