Cumulative Transactions
Hi everyone
I thought i understood the cumulative dax measure but i guess not.
I need a measure to show me in a visual table the total transactions for this year and last year, like this:
Capture
In my report view, besides this table and others, i have the filter month, which if i choose any month, it shows me the cumulative up until that month.
I also need the same measure but for a particular year, let’s says 2019, in order to be able to do another for the differences, values and percentages.
Finally, could you explain me that formula so i can understand it?
Thanks a lot all of you
Pedro
P.S. I have my Transactions Table connected to my Dates table
@pedroccamara
There are different approaches to get the cumulative totals. Here are some videos that explain in detail how to calculate the cumulative totals in different scenarios. I believe the first video is related to the cumulative total you are looking for.
I hope it helps.
Thank you bery much @MudassirAli
It didn’t help because all these videos have the same context, which is dates and my need is to show without the context, like my picture above, you know?
Thanks anyway thow
@pedroccamara Can you please share some data and provide some explanation to what exactly you want to achieve pointing out exactly how everything would end up looking.
Hey @AntrikshSharma
Glad to see you here. I’ve seen so many videos and so far, none of them suits me.
The data is completely irrelevant. Any kind will do. The purpose of this is having something like this:
There’s some measures and with this matrix visual, i’ve add year to columns. Now i want to see the cumulative values till any particular month that i choose.
I’ve tried many measures but they all show me zero when i pick a month.
Pedro
@pedroccamara
Your Transactions table is connected to your Dates Table then you can achieve this with DATESYTD function. When using in a matrix, you don’t have to use the Date Context to show the results.
The measure used to achieve the result is:
Transactions Cumulative =
CALCULATE(‘Key Measures’[Count Of Tickets Resolved],
DATESYTD(‘Date’[Date]))
I placed the Years in the Column of the Matrix Table, Transaction Cumulative in Values & Category in Rows.
Thanks a lot @MudassirAli
(It works perfectly! Awesome!)
After i’ve checked the values @MudassirAli, it seems to work because of my month filter. Let me explain : if i select 1 month, say Mar, it shows only Mar and it’s suppose to show from Jan till Mar, you know? But if i select Jan, Feb and Mar, it works but it’s not the purpose. The purpose it’s to select just one month and show the cumulative till that month.
Could you change your measure in order to work?
Thank you very much
Hi @pedroccamara
(Went to post and saw it was solved, but thought I’d post anyway.)
Here’s another idea using a disconnected dates table and 3 separate measures, one for each year like
Amount 2020 =
VAR _SelectedMonthOfYear = SELECTEDVALUE( 'Disconnected Dates'[Month Number] )
CALCULATE( [Total Amount],
    FILTER( Dates,
        Dates[Year] = 2020 &&
        Dates[MonthOfYear] <= _SelectedMonthOfYear ) )
Is something like this what you’re looking for?
eDNA Forum - Cumulative Totals to Selected Month.pbix (89.8 KB)
Hey @Greg!
Thanks for your message. I’m not sure but i believe your measure “sounds” like a regular measure of a chosen month right? And if so, what is the diff between your measure and a simple calculate sales with filter for 2020? Also, don’t forget that we were trying to have cumulative values until the month chosen.
I haven’t checked yet the values but at least they “don’t go away” when i choose a month…
Regular measure? Mine does total for the specified year for all months up-to-and-including the selected (disconnected) month. Hope it looks good after your check.
Hey @Greg
I’m so sorry, I didn’t mean to say it wasn’t a good measure. For me, that i’m very litle experienced in dax, it sounds a regular formula.
Yes, it works on your example but not in mine, because i don’t have a disconnected date table and don’t know how to change it.
Also, it would be nice to have a measure for whatever year i got in my column matrix table, and then the “same” measure for a particular year so i can make the differences between them.
Could you help me?
Thanks a lot Greg
No worries @pedroccamara … I was mobile and didn’t reply fully: I didn’t understand what you meant by regular measure; yes, it is just a normal CALCULATE with a filter for both Year and Month. If you like, you can just add a “Disconnected Dates” table using “Enter Data”:
Make sure this table is not connected to anything in your data model, and you should be good to go.
Busy day … I’ll have a think on your matrix question and post if I find a path.
@pedroccamara
The cumulative measure seems to be working at my end. You can have a look
Hi again @Greg
I guess you’re right. I believe it would work with that disconnected dates table but i would rather have not another table in my model. It would b awesome if you find a way to do it without it.
Thanks a lot
Yes @MudassirAli, i think you’re right, but…
Could it be because you have a measure for each year?
Let me tell you what i have:
First measure just for cumulative values:
Liquid Cumulative = CALCULATE( [Líquido (Mvm)], DATESYTD( ‘Tab Dates’[Date] ))
Second measure, which is in my visual:
Revenue Acc = ABS(CALCULATE( [Liquid Cumulative], FILTER( ‘Tab Mov’, ‘Tab Mov’[Cta Razão] = “71” || ‘Tab Mov’[Cta Razão] = “72”)))
and my month filter visual is also from tab Dates.
Everything seems ok, right? So is this not working :slight_smile: and your is…?
@pedroccamara I only have one measure the same as yours. I just want to confirm if your following measure is working when you filter it by months.
Do you have continuous Date Table Marked as Date Table?
Hi @pedroccamara.
I had a few minutes, and tried to simply harvest the year from a matrix, and lo and behold:
This still uses the “Disconnected Dates” table in the slicer, but now has a single measure to be used in a matrix.
Amount by Year =
VAR _CurrentYear = SELECTEDVALUE( Dates[Year] )
    FILTER( Dates,
        Dates[Year] = _CurrentYear &&
Hope this helps.
eDNA Forum - Cumulative Totals to Selected Month v2.pbix (90.0 KB)
Yes @MudassirAli
My date table is marked as date table and yes, I confirm that if I select a month it shows only that month.
As Greg rightly said you would need a disconnected table for this, the logic behind this is that:
behind the scenes SUMMARIZECOLUMNS prepares the matrix and when you have a selection on a slicer then that code will filter query generated by SUMMARIZECOLUMNS, which will result in only those months that are selected in a slicer.
Before your DAX code in PBI starts working, SUMMARIZECOLUMNS has completed its task and gives you a matrix visual on which your DAX code has to work/iterate, so in order to get running total up to and including the month selected in the slicer you will need months selection coming from a separate table that doesn’t generate a query that filters the visual and also doesn’t have a data lineage of main Dates table.
Here is how a running total like the following works, when you select multiple values it works as you want because all the selected months are returned by SUMMARIZECOLUMNS and in the filter context created by SUMMARIZECOLUMNS, MAX check for the MAX month:
Summary
This is the query generated behind the scenes.
Summary
Problem is when you select only 1 value, SUMMARIZECOLUMNS returns only 1 selected value and that is always the MAX value, it is like being only student in a night class, you are the first, last, mean, median, mode, Standard deviation etc, lol!
Summary
When you use disconnected table here is what happens:
Summary
And when I uncomment the measure it gives the desired result, because of the statement
IF ( MAX ( Dates[Month Number] ) <= MaxMonthCurrentlySelected, Result )
Which returns BLANK if Month Number in the matrix is greater than the disconnected month selected in the slicer, and DAX engine automatically removes the blank rows from the visual:
Summary
I hope this gives you some perspective. Go disconnected table!
Click on the Summary to expand/contract it.
