Nurry90
November 16, 2021, 9:19pm
1
Hi All,
Quick question, I need to correct the total showing at the bottom of the table. I cannot use any in built date functions as I dont have a standard date table. Total showing is for the whole of last year.
Any suggestions?
SamePeriodLastYear =
CALCULATE([Total Sales],
SAMEPERIODLASTYEAR(‘Date Table’[Date]))
Cumulative Total LY =
IF(ISBLANK(‘Basic Calculations’[Total Sales]), BLANK(),
CALCULATE(‘PY Calculations’[SamePeriodLastYear],
FILTER(ALLSELECTED(‘Date Table’),
‘Date Table’[Date]<=MAX(‘Date Table’[Date]))))
Keith
November 16, 2021, 9:23pm
2
why can’t you put in the EDNA Extended date table into the Model.
Hi everyone,
To make it easier to find I’ve placed the updated Power Query M code function for the extended Date Table / Dates Table in the category where it belongs… I hope you’ll find it useful and if there are any questions, just reach out and let me know!
// August 2022
There has been an overhaul of the M code from when it was initially shared. This affects column names and values. In the Analyst Hub (follow this link) you can copy a version of Extended Date table which returns a r…
thanks
Keith
Nurry90
November 16, 2021, 9:28pm
3
Hi Keith,
I had to build my own date table based on my criteria.
Keith
November 16, 2021, 9:33pm
4
You know you don’t have to use all the columns with that date table.
Did you mark your table as a date Table? I believe if its not make date table than you can’t use the built in functions?
thanks
Keith
Nurry90
November 18, 2021, 11:34pm
5
Hi Keith,
Yes I have my date table marked. I’ll see if I can build in the date table functions above to my dates, if this is the only way.
ankit
November 25, 2021, 6:11am
7
Hi @Nurry90 - I have tried at my end and doesn’t seems to be facing any issues. Please share the sample PBIX file for me to look further.
Ankit Jain
Hello @Nurry90 , just following up if you still need help with your inquiry?
If you do, kindly provide the information that @ankit is requesting above so they can help you further.
