Cumulative Discounted Sales
Cumulative Sales Bottom 5 products.pbix (471.3 KB)
I’m trying to calculate cumulative sales for the bottom 5 selling products.
Why are the cumulative a “Duplicate” of the “Cumulative of total sales”
See “Cumulative Sales w/Discounts 2”
Hi @Marmelad_Burk, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Marmelad_Burk, we’ve noticed that no response has been received from you since the 16th of December. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
