Creating & using parameters
In the video why did you adjust the M code instead of selecting parameter using the filter rows options and then selecting the parameter from the drop down menu in the ABC box. Refer to attachement.
I am trying to work out if I have missed something or is the option I listed above is new hence did not exist when the video was recorded.
Thanks in advance
Elizabeth Tachjian
Analytics Realtime
Can you be more specific around which video you are referring to?
I’m sure there are many ways to complete certain things and doing it this way is likely fine.
Some of these are also recent improvement to the query editor, so maybe didn’t exist when tutorial was made.
In the advanced transformation - creating and using parameters.
Ok so this one
I think the simple answer is that this feature was released after the video was created. Either way is fine and does exactly the same thing basically.
