Hey Guys, Thank you for your support!
I got this error when trying to create a relationship between tables with SK. ( Dimension with unique values and a Calculated table:
Calculated tables DAX:
Fact_Forecast_Days =
SELECTCOLUMNS(
FILTER( CROSSJOIN( ALLNOBLANKROW( Dim_Sensitivity), ALLNOBLANKROW( Dim_Dates)),
‘Dim_Sensitivity’[From Date] <= Dim_Dates[Date] &&
‘Dim_Sensitivity’[To Date]>= Dim_Dates[Date]),
“Active Date”, Dim_Dates[Date],
“Rate Type”, “Forecast Rate”,
“Ship Propulsion”, Dim_Sensitivity[Ship],
“Forcast Rate”, Dim_Sensitivity[Value],
“ShipSK”, Dim_Sensitivity[Dim_Ship_Granularity.ShipSK] )
the ALLNOBLANKROW was new for me, just did follow this “A circular dependency was detected”.
Can’t find any other reference for a solution.
Best Regards
Jose Milhazes
@JoseMilhazes Share sample PBIX.
Hi @AntrikshSharma , let me see what I can do!
Hi Guys,
The relation I need to create is: Between ShipSK >> ShipSK
Under construction.pbix (2.3 MB)
Regards
Jose Milhazes
Hi @JoseMilhazes! We noticed that your inquiry was left unsolved for quite some time now.
Hi All, did not find a solution to change the code on the table creation and then create the relationship. Actual did mimic in a new .pbix and did have any issue in creating the relationship. In order to solve my issue did create a virtual relation ship in my calculate column with TREATAS!
Thank you, for the effort
Jose Milhazes
