Hi I need a dax formula to count up the number of times the number five appears in a column.
Hey, Michael
simple you have to change col to Dont summarize option from coloumn tool
They write measure
Number count= Count(Stars)
Warm Regards,
Pankaj
Thank you!! Sorry if it seemed so simple.
welcome @michael.gyure
I usually just type in the search bar what I want to try to accomplish in either the EDNA forum or youtube.
I also check out the courses/labs within EDNA portal
thanks
Keith
Hi @michael.gyure ,
First chek that you Have summarization None
and then just add a measures :
You can use:
a) COUNTROWS - to count the rows in the table
b) DISTINCTCOUNT - if you have for example ID that you want count distinct values of it
c) you have other possibilities
More you can find at:
Sam’s Mastering DAX class:
Microsoft Documentation:
For Example - I will use Data Visualization Workout 1 data set :
(more about visualization of it you can check at:
Rating_Example.pbix (24.5 KB)
If you need further explanation please let us know.
Good luck.
