@Iwona , I’m new to the forum and I couldn’t find the button to reply to you. But see if this PBIX helps you.
your topic: here
051023_forum.pbix (21.5 KB)
your topic: here
Hi @VilmarSchi
the reply button is at the bottom of the message. Please see screen print below.
I hope this helps.
Keith
Thanks for the answer.
But some topics do not appear. Do I have to enable something?
nope…you might want to send a message to customer support and ask the question to them.
Customer Support customersupport@enterprisedna.co
thanks
Keith
Hi all,
@Keith I would like to mark this first post as a solution and there is no option visible for me right now. What can I do to appreciate @VilmarSchi’s solution?
Iwona
@Iwona
I don’t think there is this option, but I’m glad it worked👍. I’ll close this topic and you close yours.
sorry i’m not sure what you can do. Only enterrpisedna can do something with that
