Count of Frequency of occurrence issue
My raw data has Name, location name, Date of login. I have a virtual table which gives me location name, Frequency Group and Login Counts. Here Frequency Group and Login Count are Measures. What I really want to do is -
  1. Count How many logins per Location (Should be able to filter by year/month)
  2. Then Compare it with Frequency Group to see which bucket that count falls into
  3. Then Again count- How many Locations fall into each bucket. Meaning there are “50” locations with “1 time” logins, "20 " locations with “2-5 times logins” etc…
I did First 2 steps. I’m not able to do 3rd. Can someone help me. Here is the sample data after step 2.
Virtual data.xlsx (8.7 KB)
@pshetty,
Is this what you’re looking for?:
Total Logins Per Bin =
    [Total Logins All],
    ALLEXCEPT(
        Data,
        Data[Frequency Group]
Total Logins All = SUM(Data[Total Login])
Hope this is helpful. Full solution file posted below.
Wow! Yes, That table you have, that is exactly what I’m trying to do. But stuck with no idea to write DAX. I have ideas in other world to do this! :smile: Anyway. Thanks for the DAX. I will try this and let you know. It might be something to do with Data model too… Let me try this first.
@pshetty,
Great - if you have any questions/problems, just give a shout.
I’m sorry Brian, but calculation is not working with Year Slicer. It gives wrong counts. I will soon upload pbix file. I thin that will help better.
@pshetty,
Yes, just upload the PBIX so I can take a look at the full use case - should be straightforward to fix.
Thanks for posting your question @pshetty. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Here is the file. Sorry for the delay, I had hard time replicating with dummy data.
Login data -Test - Copy.pbix (362.8 KB)
Real Problem is Connecting date with that count. Filter is not flowing correctly.
@pshetty,
Thanks for the PBIX file - definitely makes it easier to provide a better, clearer solution.
This is a textbook dynamic segmentation problem. There are number of different ways to handle this, but I followed the approach that @sam.mckay uses in his videos on this topic.
Step 1: create a disconnected supporting table defining the parameters of your frequency bands:
Step 2: create a measure to count the number of locations in each frequency band:
Dynamic Freq Count Locations =
VAR RankingDimension = VALUES( 'Loigin Data'[Location Name] )
VAR DynGp =
COUNTROWS(
    FILTER(
        RankingDimension,
        COUNTROWS(
            FILTER(
                'Frequency Groups',
                [Total Logins2] >= 'Frequency Groups'[Band Min] &&
                [Total Logins2] <= 'Frequency Groups'[Band Max]
        ) > 0
DynGp
Here’s what it looks like all put together:
And it adjusts dynamically based on the slicer selection.
@sam.mckay has done a bunch of videos on this topic. Here are just a couple that do a great job explaining this general approach:
I hope this helpful. Full solution file posted below.
This is very cool. I knew I was not doing it right. I was watching his videos, I think I haven’t got segmentation section yet… Thank you very much for taking time to explain this. I will try myself now.
@pshetty,
It’s a really flexible and powerful technique. Here’s one more short (11 min.) video where @sam.mckay breaks down really clearly exactly what the DAX measure is doing.
Thank you. It is just the art of using formula. I think I need to use more DAX.
Superb Brian. Nice work
