I was not taking into consideration the Shipping [Shipping ID] to obtain the Total Weight per Order, now a have a better understanding of a better process.
Well…
you could hard code the ShipID instead of using SELECTEDVALUE but be very explicit in your measure name in that case - personally I don’t like hard coding because ‘things have a tendency to change’.
However if your goal is to not show the ShipID in a matrix, disable wrap in the settings and change the column width so you can’t see it. This will bring in the context without visually disturbing the report.
I’m having a hard time with the VAR ShippingandHandling though.
I cannot make it work.
The variable needs, to sum up, the ( Shipping[Shipping Cost] + Shipping[Handling Fee] ) for every Shipping ID without having the Shipping ID in the table.
For example, all the Subproducts that ends with 9 needs to be $927.64
