Copy rows (query editor)
Hi folks,
This should be a no-brainer, but what way(s), in the Query Editor, can you copy one row which can then be further manipulated? I’m not posting an example as it’s a generic question and would apply to ‘any’ row within a query.
TIA,
john
Hello @jmaikido,
Well you cannot copy a row but you can certainly create a duplicate of that row. Since I’m not sure what’s your exact requirement. I’m providing some of links of an articles as a video below for the reference -
Hoping this helps you that you’re looking for.
Thanks and Warm Regards,
Harsh
Hi Harsh,
Thnx for responding to my post.
Rgds, john
A response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!"
Great content. I learned something new from this. :blush:
Hello @jmaikido and @quantumudit,
I’m glad that you both found this post helpful. :slightly_smiling_face:
Harsh
