Can you tell me one thing when i open the pbix i find 44% i assuming it is not right can you tell me what will be the right value and how its obtain like :
As per you above description you need to first count how many customer has been converted we need to count only those customer who has one in product 2 converted
After reading your above comment i am assuming my provided solution worked for you .
For your second on this thread we can apply those filter on our calculation it self because at the end the visual filter act as filter for our calculation .
You can write like below:
EDNA Total Sales Product 1 =
CALCULATE (
[Total Sales],
Products[Product Name] = “Product 1”
It work same and did not require you to put filter on visual.
Then mark my reply which conation the pbix as solution to close this thread .
So in future some one faces same kind of issue they know which comment to look
