Hi there,
I am in need of creating Control P Chart in PowerBI
I need to build this using Scrap % which is basically sum(defects)/sum(items) plotting this on Line Chart
I need 4 Measures which are as follows Average , Standard Deviation, UCL & LCL
I got the Average and Standard Deviation to populate numbers I want
Avg = Calculate(AVERAGEX(defects_table,DIVIDE(Sum(defects),Sum(items),0)),ALLSELECTED(defects_table))
Std = CALCULATE(
(STDEVX.P(
SUMMARIZE(
defects_table
,date_dimension[WeekOfYear]
,“Defects”
,CALCULATE(Sum(defects)/Sum(items))),[Defects])),ALLSELECTED(defects_table))
I am looking to build UCL and LCL however could not get my head around this
From Youtube I understood the UCL formula to be as follows which was demonstrated on Excel
UCL : AVG+(3 * SQRT(AVG * (1-AVG)/(TOTAL_DEL_QTY/NO_OF_SUB_GROUPS)))
How can I build this or alternative to UCL above in PowerBI ?
I tried creating this but I dont get the values as expected
UCL CALCULATE(([Avg]+[Std]*3),ALLSELECTED(defects_table))
Attached is the sample data
Please guide and thanks in Advance
ControlP.xlsx (10.2 KB)
Hi @yendluru.aj, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @yendluru.aj
Regarding your needs, I would recommend that you watch this video on control charts, it includes UCL and LCL in power BI Control Charts in power BI .
Thanks and all the best
Najah
Thanks @NajahS… I have created the required Measures needed Control P Chart !
Great to hear that.
Regards
Najah
