Hi, I am trying to create a connection to our website database. The website has a custom-built CRM, products and sales database. Is the Web API key the best way to do this? Do I get this information from the web developer?
In my experience with the CRM in my previous job, I found it easiest to use âOrganizational Accountâ and pass it my authentication credentials through that option.
I have tried, but it doesnât work for me. The person before me used an API Key to connect the website database to Tableau. So I figured API Key is the only way to do this.
Is there any concerns or issues with using API Key that I need to know? I recall reading somewhere that a better practice is have a data warehouse between the live database and PBI.
I will defer to others here with much greater knowlege of data warehouse architecture than I have, but Iâm not aware of any particular concerns with using an API key if thatâs the way connection to your data is structured.
Connecting to your website database is a crucial step. While a Web API key can be one way to establish this connection, itâs essential to work closely with your web developer to ensure a smooth integration.
If youâre dealing with a custom-built CRM and database, the expertise of a professional developer can be invaluable. Consider exploring developer services and try to Hire Magento 2 developer if you need assistance.
A Magento 2 developer can help you navigate the complexities of your specific setup and ensure a secure and efficient connection to your websiteâs database. Donât hesitate to reach out to them for expert guidance and support.
