Can we change the data source from power bi web service .
For example: I created report for some one and i shared it with some one both are on pro but the user want to change the dataset of that report from the power bi .He/she do not want to use the desktop version .
Is it possible to change the dataset from power bi web (the schema of data will be exactly same)
