Been struggling with the approach to take in connecting Power BI to SAS.
I need to try and pull data directly from SAS to power visualizations and table summaries in Power BI.
A number of persons seems to favor the OLE DB approach - Others the R script approach (Unfortunately I cannot install R in the environment which requires this SAS to Power BI solution)
Any suggestions from possibly persons who have worked with SAS to Power BI
Hi @LeonW, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @LeonW, we’ve noticed that no response has been received from you since the 19th of April. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi
This is a connection question, therefore there is no relevant masked demo pbix file, data files, screenshots or visualization items supplied.
Kind regards, Leon
