I need to allow power BI to query/retrieve data from a clients database which is hosted offsite and maintained by an external third party company. Currently they only access it via a web platform.
Recommendations on connecting it and any pitfalls would be appreciated. I was thinking that the third party would need to provide some form of VPN to the database and set it up via that but not 100% sure if this is the best way and any limitations. I have googled this but nothing seemed straight forward
Hi @Hitman, what @Kumail described was an identical approach to a situation we encountered last year. Our IT team spoke with the off premise database provider and obtained access to the database through the firewall and a specific IP range.
Hi @Kumail, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Rest assured that other users will still be able to see this thread and solution even if you mark it as solved.
Hi @Hitman, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
