Conditional formatting has stopped working. Just upgraded to the Feb version and now conditional formatting window doesn’t appear at all
Is this a known issue with this version?
I’m using desktop
Hi @AliB
Which visual are you referring to? It’s moved around a bit, for example on the table visual it’s now under “Cell elements”:
it was the formatting when you right click on the measure but … it appears to be working again now so not sure what was going on - I did the usual IT cure all of rebooting to no avail
