I have a requirement which I am not sure how to solve. I want to conditionally format background of a header in the matrix visual. But I can’t see any option to set colour of the header dynamically in the matrix. Did anyone implement any workaround?
Thanks for your response. Yes, I was thinking the same that there is no option of conditional formatting of headers. What my end user expectation is that they want to provide different colours to different regions to make it more visible to end users like below:
4.The last step can be done in two way either create a theme in other tool and put your table above that theme or you can use shape how i used to create the above expected output result.
Hi @Naila, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
